I work in a club which would be approx 1000 capacity standing, approximately 40 meters front to back. The boss is concerned that the front to back sub coverage drops off too much and that there is not enough punch from about halfway down the room.
The stage is approx 20m wide, about 0.8m high. The layout is a pros theatre with audience terraces rising up about 5m front to back. There is a narrow balcony at about 7m. The club runs another venue which is similar in size and layout but outdoors. I have not heard the outdoor system but my boss has expressed the same concerns.
In the indoor club there are two, two wide stacks of subs about 20m apart, below a line array flown at approx 9 meters. The system also exhibits severe non-uniform coverage left to right, but this is of less concern to the owner. Due to the layout of the audience area the subs do fire into the edge of the first terrace about 5 meters away.
Everything I have read about sub arrays seems to focus on uniform left-right coverage, with little on front-back coverage. For this application, it is not the end of the world if the response skews towards the bass end towards the back of the room.
In an almost ideal world, assuming that subs can be flown next to the arrays if necessary, but that the array height cannot be raised, what would be sensible steps to achieve this coverage?
If you flew a long line of subs next to the array, could this be enough to even out the coverage? Could you use delay to steer the pattern of the sub array up, or would you lose impact and create noticeable problems around the crossover to the mains?
If anyone has any pointers on what solutions to investigate I would be most grateful.
