Junior Varsity
Subwoofer comparison SRX728 vs Vertec 4883
<blockquote data-quote="Jay Barracato" data-source="post: 63508" data-attributes="member: 24"><p>Hey Peter, </p><p></p><p>My thought was never to try and fill in the notch. Instead I was thinking as you said to smooth out the 200 range and decrease the peak at 1000 so the response was falling off the same way it was before the notch.</p><p></p><p>I was assuming Bennett's response was humorous because that had never even crossed my mind as a possibility until he posted it.</p><p></p><p>Anyways, as I still try to wrap my head around what out of band filters can do, this still looks to me like an example where a couple of filters will help you get flatter response a couple of octaves above the typical crossover and then fall off smoothly.</p></blockquote><p></p>
[QUOTE="Jay Barracato, post: 63508, member: 24"] Hey Peter, My thought was never to try and fill in the notch. Instead I was thinking as you said to smooth out the 200 range and decrease the peak at 1000 so the response was falling off the same way it was before the notch. I was assuming Bennett's response was humorous because that had never even crossed my mind as a possibility until he posted it. Anyways, as I still try to wrap my head around what out of band filters can do, this still looks to me like an example where a couple of filters will help you get flatter response a couple of octaves above the typical crossover and then fall off smoothly. [/QUOTE]
Junior Varsity
