Marketplace
Systems tech and sound engineer wanted in CT
<blockquote data-quote="Silas Pradetto" data-source="post: 4152" data-attributes="member: 34"><p>I'm getting more and more calls and it's getting to the point where some days I'm triple booked or more. I have a lot of people that are good at setting up gear, but I'm essentially the only one that can tune a PA with Smaart and then put together a solid mix on the rig. </p><p></p><p>My company does things the 'newfangled' way. We run networks for audio and control of various things, we use as much digital audio as we can, digital snakes, Cobranet, Crown IT-HD amps, etc. So if you're the kind of guy that likes technology, we'll like you.</p><p></p><p>Probably the one requirement is that you have a Smaart rig and can phase align subs to tops.</p><p></p><p>Home base is in CT but shows range from Maryland to Maine, with a majority being in the NYC and MA area.</p><p></p><p>If someone wants to start a good working relationship with a couple events a month, contact me and we can set something up.</p><p></p><p><a href="mailto:silas@concertsunlimited.com">silas@concertsunlimited.com</a> / PM / 8603371040</p></blockquote><p></p>
[QUOTE="Silas Pradetto, post: 4152, member: 34"] I'm getting more and more calls and it's getting to the point where some days I'm triple booked or more. I have a lot of people that are good at setting up gear, but I'm essentially the only one that can tune a PA with Smaart and then put together a solid mix on the rig. My company does things the 'newfangled' way. We run networks for audio and control of various things, we use as much digital audio as we can, digital snakes, Cobranet, Crown IT-HD amps, etc. So if you're the kind of guy that likes technology, we'll like you. Probably the one requirement is that you have a Smaart rig and can phase align subs to tops. Home base is in CT but shows range from Maryland to Maine, with a majority being in the NYC and MA area. If someone wants to start a good working relationship with a couple events a month, contact me and we can set something up. [email]silas@concertsunlimited.com[/email] / PM / 8603371040 [/QUOTE]
Marketplace
