Thinking about getting a CNC anyone running one?
Ben Lawrence
Senior
Mar 2, 2011
1,208
31
48
Vermont
vtaudiovisual.com
It seems there is a lot of crossover with woodworking on here especially how it relates to speaker cabs. I am considering picking up a hobby CNC. 16"x32" is probably the largest size I can currently see myself spending on. I definitely see the lure of a bigger cut surface but have a couple smaller projects I have in mind. All wood based. Just thought I would put it out there for any insight. Im currently looking at the Fox Alien brand which allows swapping out the spindle with a palm router for more umph. Whats a good software? I have used Easel a few time and have gotten a few reccomendations to give Carbide a try.
Drop a comment if you have any knowledge to share.
Reactions: Riley Casey
Make sure the machine is properly RIGID! We naively bought a four foot square machine which we soon discovered was based on a much smaller machine and simply scaled up using the same size rails, which will take some comprehensive work to stiffen up for heavier cuts/improved accuracy.
Don't bother using any little DC motor or even a router - fit a water cooled HF spindle of about 1kW. Your ears and cutters will thank you!
Invest in a PCD (PolyCrystalline Diamond) cutter. I know it hurts initially, however ours has already outlived the forty-odd carbide cutters which preceded it and still cuts as cleanly as the day I fitted it. The cheaper ones are sadly disposable (eventually) so you will also have to accept that it will one day go in the bin even if it looks fine...
Pay careful attention to dust clearance to reduce clogging and subsequent cutter failure. I have found that air pressure is much better than vacuum to clear the groove ahead of the cutter.
Finally, don't expect micron accuracy from a hobby machine or you'll be pointlessly chasing your own tail for ever!
FreeCad is a very good option and well supported through excellent YouTube tutorials - it's how my wife learned CAD, and it also works for 3D printing (using a slicer program).
Finally finally, what is you budget?
Well I was looking at a little hobby machine with a budget of around 1500$. No metal cutting in the plans but are you saying the pcd would be a superior choice for wood for lifespan as well? Thinking I will likely just be using mainly baltic birch and other softwoods with an occasional hardwood. I have my eye on a fox alien masuter 3s.
I did give free cad a whirl I believe a while back and the learning curve was steep. I just downloaded Carbide and it appears to likely do what I am looking for. Coming from Easel which was super intuitive.
Processed woods (we cut mainly MDF) are very tough on cutters, but carbide will be fine on low runs in ply and softwoods - they are cheap enough to use for a few hours and are easy enough to sharpen.
The machine you mention looks like it would suffer the common problem which we encountered, that of flexibility, but it is a hobby machine after all. If you take several shallow cuts it will absolutely do the job - but slowly. I'm still not sure about the little spindle though despite its nice collet chuck!
FreeCad is hugely over-spec'd for profiling; I wish they would offer a stripped down Profiling Only version! In the end, choose the CAD with which you feel most comfortable with but that also enjoys comprehensive online support (YouTube).
