Junior Varsity
Tickling the clip lights...
<blockquote data-quote="Marsellus Fariss" data-source="post: 2860" data-attributes="member: 1107"><p>What's the general consensus on the effects on amps of running a rig up to where the clip lights flash ocassionally on transients? In this case the power provided theoretically shouldn't be enough to quite reach the peak SPL of the cabs (1250watts per EAW LA460) so I assume it's relativly safe for the cabs but is there anything else I should be aware of?I set the limiters to allow the Crown K2's "IOC" lights to blink a little but keep things outta clip. It's not my style at all to run things maxed out but BE's sure as #^*% will! It's been so long since I read up on the issue I could use a refresher. And I'll go ahead and answer the obvious "enough rig for the gig" question: we've put enough iron behind the cabs to get a mix to 105dbA at FOH (10 meters) and that's all we want to provide and we use all of it.</p></blockquote><p></p>
[QUOTE="Marsellus Fariss, post: 2860, member: 1107"] What's the general consensus on the effects on amps of running a rig up to where the clip lights flash ocassionally on transients? In this case the power provided theoretically shouldn't be enough to quite reach the peak SPL of the cabs (1250watts per EAW LA460) so I assume it's relativly safe for the cabs but is there anything else I should be aware of?I set the limiters to allow the Crown K2's "IOC" lights to blink a little but keep things outta clip. It's not my style at all to run things maxed out but BE's sure as #^*% will! It's been so long since I read up on the issue I could use a refresher. And I'll go ahead and answer the obvious "enough rig for the gig" question: we've put enough iron behind the cabs to get a mix to 105dbA at FOH (10 meters) and that's all we want to provide and we use all of it. [/QUOTE]
Junior Varsity
