[FS] TOA MP-1216 16 channel monitor panel
Brian Bolly
28
28
Baltimore, MD
TOA 16 channel monitor panel in great physical shape. It's been sitting for the last 5 years, so the two pots need cleaning - a little scratchy on the volume and the channel select jumps around a bit if you try to fly through channel selects, but otherwise in working shape.
A great piece as an A2/RF Tech monitor panel for large wireless mic setups (often used as such on Broadway).
Accepts balanced and unbalanced line level, 4 ohm, 8 ohm, 25 V, 70 V and 100 V speaker level signals.
Can be slaved to a second unit for up to 32 channels of monitoring.
http://www.toaelectronics.com/products/mp-1216.html
$100 shipped in the lower 48
