In reply to a comment about a double 18"not keeping up with a full range box (from another thread, to me this is it's own monster):
And an article that was linked for my viewing on facebook yesterday.
http://www.audiotechnology.com.au/wp/index.php/time-to-shelve-the-low-end/
I am definitely in agreement with this article. It is also how I implement. In fact I go further (less further?) than this.
I have written on forums before about some of my business practices, and how I will charge more for including subs. (I consider lows and subs to be two different entities.) My logic being that the subs are what takes up all the truck pack, the labor, and the electricity. Lots of times providing subs pushes me from using wall power to power distro.
Please realize that i am doing community events, not providing for nationals in arena's, or doing EDM.
But my experience is that no one misses the subs. No one clamors for the "punch" or "the excitement".
I get plenty of suggestions, comments, and compliments, and there just is no suggestions for more kick drum.
Last fall my wife and I went to see Imagine Dragons in the local arena. It was a hot subby mess.
Lots of sub excitement!!! But just could not hear the vocals. At all. I tried to not show my disappointment, as she is such a big fan, and was having a great time. But I just think that things could be so much better.
(edit) Upon re-reading, it seems that Ivan might be a proponent of this behavior. It is taken out of context, as it seems that this needs its own thread. Ivan is describing, not prescribing. He can weigh in with his own thoughts here.
It all depends on what the ratio of mid/hi to sub energy is. Different people like different amounts.
My experience is that after "adjusting by ear" a system (basically turning up the subs until it sounds "right"), and then measuring the system, the subs are in the range of 25-30dB louder than the full range cabinets for EDM style music.
So basically below 100Hzish it is 25-30 dB louder than above. Of course there is a big slope around 100Hz ish, so lets say above 300hz vs below 90Hz.
I know this sounds extreme-but I have done it a number of different times-with different people-on different systems in different places.
So as you can see-you need A WHOLE LOT more sub output than full range output-for that type of music-to be represented in the way the artists want it.Of course many times people simply don't have enough sub to "outrun" the tops, so the ratio is lower and they just live with it.
But when "given the choice" a wide variety of people in the US like that.I use that as a "starting point" for suggesting sub to top output range.
So for a top that is 130dB, you should be looking at sub outputs in the 155-160dB range-IF you are going to run the tops at full level.
And remember that the average level as read on a meter is going to be 10-15dB lower than the peak calculations.
