One of my LA400's blew so I'm thinking of upgrading to a more powerful speaker. Has anyone done this and/or does anyone have suggestions?
Simply sticking a "more powerful" driver in a horn is usually not a good idea. The horn was designed with a specific loudspeaker in mind.One of my LA400's blew so I'm thinking of upgrading to a more powerful speaker. Has anyone done this and/or does anyone have suggestions?
Would I be losing if I replaced both my LA400 drivers with Eminence Lab 12C drivers?
You can get the right one from EAW for probably about the same price.
If you need more output, get more subs.
Russ,Would I be losing if I replaced both my LA400 drivers with Eminence Lab 12C drivers?
Russ,
The Lab12C will have a minimum impedance of around 3.11 ohms, so a pair (unless in series) would be too low of an impedance for most amps.
In addition, the Lab12C Fs is only 22.85 Hz, almost an octave below the LA400 horn Fc (cutoff) which will make it much less efficient in that horn than the proper driver.
As I recall you measured the Lab 12 impedance minima in Labhorns approximately 2/10th of an ohm higher than the DC resistance, and the Lab 12C is 3.11 DCR compared to 4.29 for the Lab 12.Art, the horn is obviously going to add quite a bit of impedance, but that is a side discussion that doesn't matter for this OP.
Impedance minima in most horns is very close to DCR, since when is impedance not a concern in a purchase decision?
The amp does not care about the minima unless you're playing a sine wave centered there. Since music doesn't happen like that (usually), the average over the passband matters more (IMHO). I ran pairs of LAB subs on various bridged amps all the time with no problems (except Crown XTi).
Impedance minima would always be very close to DCR, no?
There are several different ways to calculate an impedance average, which would result in result in several different answers.How would one calculate the average over the passband of a particular speaker?
You can look at the impedance CURVE to get an idea.How would one calculate the average over the passband of a particular speaker?
