Am I correct that VCA or DCA are control groups whereas POP groups offer no control but simply bring all assigned channels to the surface for individual tweaking?
Thanks.
Thanks.
I am a Network Admin by day.
Thanks.
Yes sir, Basically. Here is a quote from Midas website.
"If you think of the VCA faders as if they were each containers for all the channels they control then finding channels becomes a natural and easy task. This method is further expanded through the provision of user customised POP (POPulation) groups each of which can contain any combination of channels that you want to accesses instantly at the press of a switch. Rather like a VCA without a fader."
What's the difference between a POP group and a "user assignable layer" in Yamaha-world?
I believe the basic difference is that the POP groups will pull things out of multiple layers. A user assignable layer may in effect be the same, but my guess is that a desk with POP groups just gives you more groups than you'll get by using layers. But what do I know.....
Hopefully more people will chime in.
On my Yamaha DM 2000 there are 5 "layers":
ch 1-24
ch 25-48
ch 49-72
ch 73-96
Master (bus/aux/mtx)
And then I can build 3 more "custom layers" that can be any combination of anything on the 5 other layers.
Only limitation is that the same input/output channel can't be assigned twice to the same user layer.
Interested to hear how the POP groups are different from this![]()
