Re: Venice F
Hi Marjan,
sure no problem.
I was always interested in alternative ways of mixing. I started in the late 1980s with analog mixers (with a Mitec EX) and the usual siderack and coppercore madness. Than I bought one of the first digital mixers available (Yamaha ProMix01) and did all my small gigs with that. Than I bought a Soundcraft Venue and a Yamaha 02R and did my studio and live work with that. In the Studio I used a Soundcraft 2400, after that a DC2020 and finally bought a RME Hammerfall card with RME convertors and went very early the "InTheBox-route". Two years ago I stumbled over SAC (
SAC - Software Audio Console ) a virtual live mixer, that lets you use your favourite VST Plugins in a live enviroment. I was sold right away. After two years I run into the Behringer X32 and love it too. Meanwhile I sold nearly everything from my analoge gear, but I did not have the heart to sell my old Soundcraft Vienna II. If you look into evilbay, the prices for analog desks are insanely cheap. Lately they sold a A&H ML5000 for under 2.000,- EURO (Case, PSUs included), or a Midas XL3 for just 2.400,- Euros! So I thought, I keep my Vienna II...even if I don't use it anymore.
Than I run into LiveProfessor lately-->
LiveProfessor |
Which is a very economical VST host software. So I thought, why not use this as digital siderack on my analoge Soundcraft mixer? The missing link is a propper Windows PC and a soundcard. Due to my experience with SAC, I know at least a bit, how to tweak windows and what soundcards are good for real time audio. Of course, I wanted the cheapest possible combination, so I used my old SAC desktop PC (Core2Duo, E8400 CPU, 4GB RAM, Windows XP pro) und bought some dead cheap PCI soundcards. I use two Terratec Mic8 convertors with two Terratec EWS88MT PCI cards. If you want to go really cheap, than look into these-->
Terratec EWS88MT
I see these cards with breakoutbox for about 50,- Euros on ebay. You can hook up up to four (!) of them...if you find a mobo with four PCI slots
Anyway, or you buy some of the old RME or MoTu PCI stuff...it will run with 64Samples, that gives you an overall latency of 3ms from analog in to analog out. Good enough for Live use.
Stay away from USB or Firewire soundcards, those will always ad a security buffer to your overall latency and in addition will not perform so stable when dealing with a high channel counts and/or high CPU load.
Now you will need some plugins. I have a lot of them, because of my studio work, but there are lot's of good freeware plugins out there, that will do the trick.
Here is a nice list:
Freeware and donateware plugins - SAWStudio / SAC User Group
In the end, you just have to connect your analog desk with your soundcard/computer/LiveProfessor. That's it!
By now, I have a default scene in LiveProfessor, that covers a basic rock band needs:
Valhalla Reverb
Waves Super Tap Delay
6 x Waves SSL Channel (Drums+Bass)
1 x Drumagog (Kickdrum)
5 x Fabfilter Pro EQ (for my monitors)
For the mains I use one analog 31Band EQ, the rest is covered with the LiveProfessor setup. By now my Vienna II is in service (PSUs and the power distribution board needs help), but I will get it back next week.
Than I will hook up my PC and if everthing works like it should, than I will install this combination in a 400pax club, where I'm the residential mixer guy.
I won't take my Vienna on the road anymore, but I see a future for this kind of "hybrid mixing" particularly in permanent installs. I will let you do things, that you can't do with a normal desk!
I will post some pictures, when I got it working.
LiveProfessor and Venice F is a bit easier, because you can use the build in firewire soundcard. Unfortunately Midas uses the DICE junior FiWi chip, which I could get to work with 64Samples, but the Fiwi security buffer that comes along with it is quite big. I couldn't get the latency lower then 7ms - sketchy at least. But LiveProfessor is a nice piece of software and I'm courios how it turns out in the end.
Christian
