Junior Varsity
Very faint output to mains from most channels - ProFX16 mixer
<blockquote data-quote="kyn thar" data-source="post: 218916" data-attributes="member: 17515"><p>It sounds like the main output section might be damaged or loose after moving. Try checking all cables and connections first. If that’s fine, the mixer may need a repair or service.</p></blockquote><p></p>
[QUOTE="kyn thar, post: 218916, member: 17515"] It sounds like the main output section might be damaged or loose after moving. Try checking all cables and connections first. If that’s fine, the mixer may need a repair or service. [/QUOTE]
Junior Varsity
