White lapel microphones????
Re: White lapel microphones????
Will a white windscreen and some careful use of white electrical tape or heatshrink tube work for you?
<edit to add>
Looks like all the Countryman lavs are available in white, including the EMW (which is somewhat less expensive).
The capsule for the Shure WL183/4/5 is available in white, but I don't think the rest of the mic is. Might be worth a call the Shure though.
Mike,
You might also consider nude/flesh-toned elements. The bride may not be overly-keen on being wired up on her wedding day. Have you considered wiring up the groom? You could (more often than not) use black.
