A church we've done some work for in the past has asked would like a speaker installed in their nursery.... which happens to be located in another portion of the building that has open ceilings on both floors and is made out of poured concrete. This means that what at first seem to be a small job is rather more expensive once the many hours of labor to drill and cut through all that concrete are added up. So that brings me to looking at what some other options might be, and of course wireless comes right to mind.
Does anyone have any experience with something like this:
http://www.williamssound.com/productdetail.aspx?product_id=370
Their current ALS system is an older Telex Soundmate deal so I'm not sure if this would even work. I'm also not hugely keen on the fact that it requires the user to make adjustments on the speaker itself, as opposed to a simple wall mount volume control as the case would be with a standard 70v system. I'd also be concerned about the audio quality and dropouts as I'm not sure how well these systems transmit.
Are there any other wireless systems that would work in this way but with a wall mount volume control? Does the Williams Sound unit even work? Experiences? If it's not do-able it's not do-able but I figured it was worth asking.
Thanks!
Thanks!
