WTB: Used AT wireless with belt pack
Re: WTB: Used AT wireless with belt pack
Hi Rob, not usre exactly what you're looking for, but I have several AT1200 series beltpacks and receivers available from the little theatre I work with. Someone just donated 8 new 3000 series units. All the ones available are in the 170-215Mhz range and are in good working condition. They do NOT include microphones. Looking to get $125 each but my arm could be twisted.
Al
A-T has used a 4 pin locking connector for years on their "pro" stuff. It resembles a mini XLR female but with four pins (this is on the mic cable itself - the belt pack has a male built in to it) This allows them to use a single connector for either a balanced mic or an unbalanced instrument cable. 1 pin is a common ground, 2 pins are the balanced + and -, and the fourth pin is the + instrument connection. Internally the belt pack has separate screw driver addjustable gain controls for both the instrumetn input and the mic input. The receiver has XLR and 1/4" outputs as well as an output level control and LED metering of both AF and RF signal strength. Hope this helps.
Al
