Sean, there is almost ZERO value in presets for compressors unless you have a couple of favorite settings you use often or build a library of settings for individual performers who require unusual settings and that rotate through (like a church band). For the most part, by the time you find a preset and load it, you could have just turned the knob...
Rather than input templates, I find *configuration* files to be more useful: FOH only, MON only, FOH/MON from same console, different operator preferences (cue follow/select follow, mix bus inserts, FX selections). All of them can be built off line with x32 Edit.
And speaking of Edit.... download it and use it to learn the mixer if you don't have full time access to the actual desk. It's very complete...
