Junior Varsity
X32, DCAs, Groups, etc.
<blockquote data-quote="Todd Warnock" data-source="post: 12227" data-attributes="member: 9175"><p>Apologies for this "novice" question, but - as the group indicates, I've got a "day job", and sound engineering isn't it! That said, here's our situation...</p><p></p><p>We've got an X32 with the S16 digital snake (two) and the P16 in ear solution (8 stations.) Everything is up and running and working "fine" with a few exceptions. </p><p></p><p>I'm not sure I totally understand the whole DCA/Group thing, and I've read forums and watched videos and still can't figure it out. (So, while I know what I have is wrong, I'll tell you what I haved with the hopes that someone can give me some detailed instructions on how to fix it (or where to get help.)</p><p></p><p>We have 3 DCAs that group Vocals, Instruments and Drums. They're on individual busses (I think that's right - I don't access to the system during the week, only on Sundays.) The need (original thought) was that the DCAs would allow us to adjust the drum mix as a whole (and the same with vocals and instruments). However, in doing so, it affects our in-ear volume on the P16. Obviously, that's a problem.</p><p></p><p>What I'd like is to individually be able to adjust the drum mics (8 of them) on the individual channels and have it affect the house volume. Ditto on a slider to affect the whole group of mics (the drum mix.) Neither should affect the P16 mix/gain.</p><p></p><p>I know this is probably an easy fix. Somebody - what am I missing?</p><p></p><p>Thanks!</p></blockquote><p></p>
[QUOTE="Todd Warnock, post: 12227, member: 9175"] Apologies for this "novice" question, but - as the group indicates, I've got a "day job", and sound engineering isn't it! That said, here's our situation... We've got an X32 with the S16 digital snake (two) and the P16 in ear solution (8 stations.) Everything is up and running and working "fine" with a few exceptions. I'm not sure I totally understand the whole DCA/Group thing, and I've read forums and watched videos and still can't figure it out. (So, while I know what I have is wrong, I'll tell you what I haved with the hopes that someone can give me some detailed instructions on how to fix it (or where to get help.) We have 3 DCAs that group Vocals, Instruments and Drums. They're on individual busses (I think that's right - I don't access to the system during the week, only on Sundays.) The need (original thought) was that the DCAs would allow us to adjust the drum mix as a whole (and the same with vocals and instruments). However, in doing so, it affects our in-ear volume on the P16. Obviously, that's a problem. What I'd like is to individually be able to adjust the drum mics (8 of them) on the individual channels and have it affect the house volume. Ditto on a slider to affect the whole group of mics (the drum mix.) Neither should affect the P16 mix/gain. I know this is probably an easy fix. Somebody - what am I missing? Thanks! [/QUOTE]
Junior Varsity
