Junior Varsity
x32 / M32 Monitor/IEM issues
<blockquote data-quote="Andrew Broughton" data-source="post: 12817" data-attributes="member: 318"><p>Had a chance to play around on the M32, mixing monitors the other day. Very much enjoyed the iOS M32-Mix app as well.</p><p></p><p>One thing that seems really strange is that when mixing IEMS, setting the console to fader flip, the PAN control still only pans the L/R send rather than the mix send. In fact, panning the channel to a mix is not very easy at all. Really slows down setting up IEM (stereo) monitor mixes.</p><p>On the iOS app, M32-Mix and M32-CUE there is also no pan control for mixes. This is a real problem, unless I'm missing something. Others I asked did not know an easy way to pan either.</p><p></p><p>Is this simply a glaringly missing function, or is there a setting to change the Pan control on the surface or a setting in the iOS apps I'm missing?</p></blockquote><p></p>
[QUOTE="Andrew Broughton, post: 12817, member: 318"] Had a chance to play around on the M32, mixing monitors the other day. Very much enjoyed the iOS M32-Mix app as well. One thing that seems really strange is that when mixing IEMS, setting the console to fader flip, the PAN control still only pans the L/R send rather than the mix send. In fact, panning the channel to a mix is not very easy at all. Really slows down setting up IEM (stereo) monitor mixes. On the iOS app, M32-Mix and M32-CUE there is also no pan control for mixes. This is a real problem, unless I'm missing something. Others I asked did not know an easy way to pan either. Is this simply a glaringly missing function, or is there a setting to change the Pan control on the surface or a setting in the iOS apps I'm missing? [/QUOTE]
Junior Varsity
