Hey guys! I need some advice please...
I'm running on a Behringer X32, and I'm trying to develop a mix without having the band play continuously for me as I mix. What I did is I recorded the band multi-track into my laptop, and now I use each track as an input for each channel on the X32, respectively. The problem comes in when I begin switching input sources on the board from the Local Inputs to the Card Inputs. It seems that the Local Inputs have a different Gain Staging system than the Card Inputs do.
I've noticed that the Gain Control is literally called "Gain" when the channel is in Local Input mode, and changes to "Trim" when in Card Input mode.
Additionally, the dB range changes. Gain dB range is from -12dB to +60dB, while Trim dB range is from -18dB to +18dB. Also, the board saves the Gain/Trim level independently from one another.
This introduces a problem. Here's what happens:
I have a live kick drum playing, and I'm recording it into computer. Suppose my Gain is set to +5dB.
My drummer leaves, and I'm off to mixing on my own.
I change the input source from the Local Input to the Card Input, and bam! My Gain, or Trim in this case is now at, oh I don't know, let's say -10dB.
Of course I can change the level BACK to +5dB, provided I remember that the Gain was actually at +5dB to begin with.
But is this correct to do?
Now imagine an entire band playing live, each with a given Gain level, everyone recorded into computer. As soon as the band leaves and I switch to Card Inputs, now my entire mix is thrown off because first of all, the Trim is at a different dB (saved to whatever setting it was at when previously used), secondly, the dB ranges are completely different, and this is a problem all on it's own because supposing that the Gain was at +25dB on some given channel, I see no way to set the Trim to +25dB when Trim only goes as high as +18dB.
There's something I'm radically missing here.
First of all, why does the board switch from Gain to Trim, including the range differences?
Secondly, is there a good way to be able to mix my band from computer while they're not there, so that when they DO come back to the studio, the mix is all nice and ready from them?
Thanks guys!
Thanks guys!
