X32 parameter safe problem.
Kevin Maxwell
313
5
I was playing with the xcontrol and the xedit software and discovered something that doesn’t seem to be right. They both behave the same way so it is consistent. In the scene view if you select param safe and input channels (the first column) the mute selection. If you select mute it also seems to safe the fader also not just the mute.
Is this only the offline software that behaves this way or is it also the console.
Re: X32 parameter safe problem.
So far around 115 views and no answer.
Is there anyone that knows how the X32 works as far as parameter safes and can please try it on their console? If you safe the mute does it also safe the fader?
I may get my hands on one late next week and I will try it and report back here.
This is TRUE - I reported it to one of the Behringer team during a webinar.
There are other issues with current xedit e.g. With Core & S16 the HA lock function from xedit does not work ( though ok with the classic x32)
There maybe others - hopefully v2 will sort these out!
