Junior Varsity
XTi presets for the ol' JBL SR4732X?
<blockquote data-quote="Greg Cameron" data-source="post: 4901" data-attributes="member: 42"><p>I have a friend with a set of these tops and a Crown XTi4000. I downloaded Band Manager 2.0 to see if there are presets for these older boxes. But alas you can't get to those libraries without the amp actually connected to the software (probably because the presets live in the amp firmware). I wanted to confirm they're actually there and that there are both full range and bi-amp versions before I start helping him out. For now he'll run the tops passive full range with the XTi4000, but the goal will be to add a XTi 1000 to that and bi-amp them later.</p><p></p><p>Thanks,</p><p>Greg</p></blockquote><p></p>
[QUOTE="Greg Cameron, post: 4901, member: 42"] I have a friend with a set of these tops and a Crown XTi4000. I downloaded Band Manager 2.0 to see if there are presets for these older boxes. But alas you can't get to those libraries without the amp actually connected to the software (probably because the presets live in the amp firmware). I wanted to confirm they're actually there and that there are both full range and bi-amp versions before I start helping him out. For now he'll run the tops passive full range with the XTi4000, but the goal will be to add a XTi 1000 to that and bi-amp them later. Thanks, Greg [/QUOTE]
Junior Varsity
