I need to reserve some equipment and a tech in the Philadelphia area for a noise transmission test. The equipment will be needed at the following locations:
1. 113 South 16th Street, Philadelphia, PA
2. 2 Coulter Avenue, Ardmore, PA
The date will be either 8/25 or 8/28. Start/end times are also TBD, but 2.5 hrs of tech time at most will be needed at each location.
The tech needs to deliver and set up the equipment, assist an acoustical engineer with operating the system while she conducts sound level measurements inside the space and in adjacent spaces, and then strike the equipment. Repeat at the second location.
Please contact me directly at daniel dot postilnik at soul-cycle.com if you are available and I can give you more details.
Thank you!
Thank you!
