A couple of Time Frequency Analysis MATLAB programs
These should work in MATLAB or Octave.
A simple pseudo Wigner-Ville Distribution.
Code:
[FONT=courier new]function [ WD, f, t ] = wvd( x, Fs )[/FONT]
[FONT=courier new]%WVD compute discrete wigner-ville distribution[/FONT]
[FONT=courier new]%   x - analytic signal[/FONT]
[FONT=courier new]%   Fs - sampling frequency[/FONT]
[FONT=courier new]
[/FONT]
[FONT=courier new][N, xcol] = size(x);[/FONT]
[FONT=courier new]if N<xcol[/FONT]
[FONT=courier new]    x = x.';[/FONT]
[FONT=courier new]    N = xcol;[/FONT]
[FONT=courier new]end[/FONT]
[FONT=courier new]
[/FONT]
[FONT=courier new]WD = zeros(N,N);[/FONT]
[FONT=courier new]t = (1:N)/Fs;[/FONT]
[FONT=courier new]f = (1:N)*Fs/(2*N);[/FONT]
[FONT=courier new]
[/FONT]
[FONT=courier new]for ti = 1:N[/FONT]
[FONT=courier new]    taumax = min([ti-1,N-ti,round(N/2)-1]);[/FONT]
[FONT=courier new]    tau = -taumax:taumax;[/FONT]
[FONT=courier new]    WD(tau-tau(1)+1,ti) = x(ti+tau).*conj(x(ti-tau));[/FONT]
[FONT=courier new]
[/FONT]
[FONT=courier new]WD = 2.*fft(WD);[/FONT]
[FONT=courier new]
[/FONT]
An inverse FFT which always returns real values.
Code:
function [ x ] = idft_real( X )
%Return inverse FFT always real
Y = real(X) + imag(X);
y = ifft(Y);
x = (real(y)+imag(y));
end
An alternate to the MATLAB hilbert function.
Code:
function [ z ] = analytic( s )
%ANALYTIC Compute the analytic function
N = length(s);
S = fft(s,2*N);
S(2:N) = S(2:N).*2;
S(N+2:2*N)=0;
z = ifft(S);
z(N+1:2*N) = 0;
end
Re: A couple of Time Frequency Analysis MATLAB programs
Sorry I guess I should have put the example of how to use it here. All of these functions need to be placed in files which have the name of the function and then all dropped into the same directory in octave.
There are two more functions which are useful for making log sweeps.
Generate the phase of a log sweep, this is from the integral of the ideal IF.
Code:
function [ tt ] = logphase( t,T,w1,w2 )
%LOGPHASE Logrithmic phase trajectory
tt = ((T*w1)/log(w2/w1))*(exp( (t/T)*log(w2/w1)) - 1);
end
Generate the log sine sweep
Code:
function [ x t ] = logsweep( f1, f2, T, A, Fs )
%LOGSWEEP generate sweep from w1 to w2 of length T
%   f1 - sweep start frequency in Hz
%   f2 - sweep end frequency in Hz
%   T - duration of sweep in seconds
%   Fs - sampling rate in samples per second
%   A - amplitude
t = 0:1/Fs:(T-(1/Fs));
w1 = 2*pi*f1;
w2 = 2*pi*f2;
tt = logphase( t,T,w1,w2 );
x = A.*sin(tt);
end
% end sinesweep
Example of how to use the WVD to visualize the sweep.
Code:
function example
%EXAMPLE
f1 = 20;
f2 = 200;
T = 1.0;
A = 1.0;
Fs = 1000;
x = logsweep( f1, f2, T, A, Fs );
s = analytic(x);
[ S, f, t ] = wvd( s, Fs );
contourf(f,t,abs(S));
end
I would like to point out that the WVD and other Time Frequency Representations are not from the field "Wavelets" for the most part. Although the two fields of study are closely related. In fact the way wavelets are used in the Wavelet TFR is not typical, they are used more as a window function. Not that there are not lots of cool things that wavelet processing can do. But you will turn up a lot more useful information on Time Frequency visualization and processing if you don't search for wavelets.
