Hi All,
Taking over the sound system at a small rural church. I'm a total novice, so thanks for being patient with me...
The old system was an 8-channel preamp connected to a 750w x2 power amp. I replaced the 8-knob preamp with a 16-channel digital mixing board (Mackie Dl1608).
We have two large main speakers mounted to the side walls firing out to the congregation, with two smaller monitor speakers mounted directly beneath the mains firing back toward the stage.
In the original configuration, one of the two amp outputs was connected to the 'main' speakers, and the other amp output was connected to the monitors. So in the original configuration I could control the level of the monitors, but they had the same content as the mains.
I only have the one power amp, so in other words, the 'left' channel was sending mono to BOTH main speakers and the 'right' channel was sending mono to BOTH monitors.
I have reconfigured it so that one of the main outs feeds the amp's left channel and Aux1 feeds the amp's right channel, so at least I have full control of the monitors separate from the mains. But no control from one side of the hall to the other.
I'm thinking about adding a 2nd (smaller) power amp, and running Main L&R on the old amp, then two Aux Sends to the new amp.
The monitors being on the side walls may not be ideal, but that's what I've got. And I'm thinking this new amp could drive the sidewall monitors on one channel and use the other channel to drive some floor jacks for portable monitors on the stage.
Does that sound like a good plan?
Any recommendations on an amp for monitors? The existing amp is a Peavey GPS 1500 if that matters. It's probably overkill in this application; I don't think we're driving it anywhere near its limit.
