Adjustable Rack Rails?
Ben Lawrence
Senior
Mar 2, 2011
1,185
29
48
Vermont
vtaudiovisual.com
Hi I just got a little Crest XR20 and all the patching is on the back where I cannot access it with the current roadcase I have. Is there a vendor for the rack rails that ratchet up to an angle and lock into place ? I have seen them on some skb cases and some other mixer cases. Drop a link if have any info. Thanks.
Re: Adjustable Rack Rails?
I have a gator case with the popup for a mixwiz. I still had to fold the input section down. I am not sure if you can just buy the rack rail part.
By the way, that XR20 is an absolutely sweet little mixer.
Always and loved and hated that about this mixer. If it doesn't work out for you then maybe the next option would be to built a quick disconnect for the items that are found under the hood. Seems like I remember that all of the aux masters, matrices and sub groups are under there. Most people that I have seen have had one of those gig rig style molded systems our a stronger version of a studio rack with the top slanted. They do make a hinged rack system, but it's more for patch panels that wouldn't need the clearance that the Crest would need (because of it's depth)
You might also give R&R cases a call and see what they have done for this mixer.
