I'm looking to drive four mix monitor racks with a single 6 pin XLR, or even 5 pin if they can share the ground. Just wondering if anyone's been successful and if so what cable do you recommend?
I would probably use Neutrik ethercon and something like Belden 1305a. Excellent AES/EBU cable.I'm looking to drive four mix monitor racks with a single 6 pin XLR, or even 5 pin if they can share the ground. Just wondering if anyone's been successful and if so what cable do you recommend?
I chose a career in the production industry, so besides having my head examined, I would rather devise an extensive & elaborate plan to shave seconds off of the set-up and tear-down times. Spend hundreds if not thousands of dollars on fancy cabling, connectors, and rack panels. Spend days if not weeks designing, wiring, and implementing the idea. And then lastly, in a about a year when I'm bored with it all, I will sell it for probably less than scrap value.Why not just 2 * 3pin taped together though?
Make sense?
Make sense?
One can hope!Yeah, specially the part about making your set up rely on custom cables not available from anyone else, so when they fail and take down your system you can just pack up and go home rather than working all night.
Mac
Mac
Joking aside, Mac, all of our panels have XLR male & female wired to the amp inputs, so the 5 or 6 pin would just make things neater & quicker when using a digital console/stagebox with aes/ebu outputs.
AES/EBU works absolutely fine without the shield. Belden makes a digital audio cable without shield: http://www.belden.com/docs/upload/NP267.pdfSTP cat5 in an Ethercon should also work nicely, and gives you an upgrade path down the road (and with the right breakout wiring, could carry 100Mbit Ethernet in addition to your 2 AES streams - Powersoft is doing this with their KAESOP wiring).
