I am just trying to figure out some AES interconnection basics and ran into a situation where I can't figure out if things should be working or not.
I have a SC48 and an 01V96 with a MY8-AE96 card. Both the mixers are running off of a master clock set to 48k.
I can send AES from the MY8-AE96 to the SC48 without a problem. I am guessing because there is a sample rate converter on the AES 2-Track In. However, I cannot reliably send AES from the 2-Track out to the MY8-AE96 card, when the clock is set to "Word Clock In" in the 01V. It shows up, but cuts in and out. If I set the clock source is set to "slot in" then it works fine.
This is not an actual scenario, I am just trying things out. I sure thought that if the source and the receiver were sync'ed off the same clock there wouldn't be any problems.
