The BF121 is a high-performance subwoofer system, delivering tight and accurate bass response with very low distortion. It features a single 12” long-excursion woofer, with double-spider suspension and 4” voice-coil in a bass-reflex configuration.
The direct-radiating woofer is mounted in a vented chamber, with large bass reflex port for excellent breathing capacity, increasing overall output while minimising port-compression. The frequency range is tuned to a -3dB response from 40 Hz to 300 Hz and 33 Hz at -10dB.
“Ever since we introduced the VR5 ultra-compact monitor, we had clients asking for a smaller sized, accompanying subwoofer, but with the same Alcons sonic footprint, for both portable as well as install applications.” Philip de Haan, head of R&D Alcons Audio.
For full system performance, the BF121 is driven and controlled by the ALC amplified loudspeaker controller; Driven by the ALC, the BF121 delivers maximum sound quality and output power with long-term operation...
Continue reading...
