I got my GLD today. I haven't had a chance to run a gig on it, but did have a few thoughts.
Build quality:
The surface generally seems very well built. The touchscreen is really responsive, and construction feels nice. For some reason I thought the buttons would be hard plastic, but they're soft; not that that means anything. The only thing that's worse than I hoped is there are a couple glued on overlay stickers that seem a little cheap. There is a little noise from the fan on the surface, but not a huge deal.
The dimensions and small weight of the console are incredible for what the board can do. I've ordered a lightweight custom case, and the surface in the case will be about 60lbs - incredible for a 48-channel console.
The AR-2412 rack is lighter than I expected. Mine came with a defective fan - it's really noisy. Other than that, it's fine. I also ordered the expander module, but that hasn't shipped yet.
Software:
The board is generally easy to get around on. I like that the touchscreen supports dragging - both for channel assignments, and also with very IPad-like scrolling in the onboard help.
A few things that are strange and/or I'm missing:
Bus assignment - mono busses and groups can't be added singly - i.e. you can't have 5 mono auxes and 3 groups - you have to have even numbers. This isn't a huge deal, but for fully using the board, this might cost a bus or two.
LR+M main mode - I haven't figured out how to assign separately to the L+R and M. M appears to be just a sum of L+R. I was hoping to use this for group-fed subs, but apparently I actually need to use a "group".
USB recorder: This is really handy. Currently recording is only 16-bit. It would really be great if they allowed the full 24-bit resolution of the board to be recorded, which is especially useful for multi-element events with both loud music and speech where lots of makeup gain is added in post for the quiet parts.
Manual:
The included manual is fairly thin, and my copy was extremely poorly printed. I expect that this will get thicker as time progresses and A&H continues to refine the product.
So far all my complaints are very minor, and this feels like a really solid product. I'm confident that a few rough edges will be dealt with in future software updates.
More thoughts will follow as I get more time on the console.
Build quality:
Software:
Manual:
