Would moving from 4 eaw 650z with ux8800 to 6 apogee 3x3s2 be a good move? I know the 3x3 are older. Can you still get parts? Any thoughts would be great.
Thanks guys. I thought everyone would tell me to stick with the 650's. I like the way they sound, but they seem to be weak in the low mid. That's why I was thinking of getting something that was just a little bit better.
Silas the 15's are powered with two qsc 6.0pfc in stereo which is about 1400 watts per 15.
The limiters hit before the amp clips. I will play around with the limiter settings.Yep, I don't think you're going to get much more out of them! Are you constantly hitting clip lights, or is it more of a general system EQ or limiter problem? I hear the 8800s have limiters that are difficult to get right - they often limit early.
I assume you are using them with a sub (?) if so raise the sub / low mid crossover from 90 Hz to 120 Hz and see how you go.
I have the subs running up to 90hz now. I'm using Jbl sr4719x as subs. I stack two subs on their sides and then put the 650's up. I did delay the subs. I have not used any software to figure the delay though. I did the invert the subs and play with the delay. I ended up somewhere around 5ms I think. Would it make a huge improvement to have smart figure out the delay? I have been looking at getting smart or something along those lines. I have even thought about bringing one of the forum member in and do smart for me. Do to the limited knowledge of smart on my part.
Hi Eric
JBL rate the sr4719x to 1.1KHz http://www.jblproservice.com/pdf/SR-X%20Series/SR4719X.pdf... so I don’t think you will have a problem if you cross over a little higher.
The delay … my guess is it will be between 2 to 5ms – put a tone in at that frequency and adjust the delay for maximum output (sub + 650) … or do the opposite; invert the polarity of the sub and adjust for maximum cancellation, and then flip the polarity back (many years ago JBL used the opposite polarity on their speakers to everyone else … not sure about the 2241’s in your box - you may need to check)
FWIW a while ago some of us started compiling a list of the appropriate delays for EAW speaker combinations with the UX8800, no 650z’s but from memory it was less than the SB528/650e listed below.
SB528(5ms) with KF650i/E
SB528 (4.5ms) with KF730
SB730 (3.75ms) with KF730
SB730 (2ms -6db) with 2 x JFX260i BiAmp
SB750 (7ms) with KF750 (using KF750x2-4 TRI Greybox)
SB750 (8ms) with KF750 (using KF750+KF755 TRI Greybox)
SB750 (4.5ms) with KF730
SB850 (4.5ms) with KF730
…anyway I don’t think with your setup you will have any problems if you raise the crossover to 120 or so. You will lose a little sub output but it will take a lot of strain of the 15’s in the KF650s.
Are you running the 650's 2-way or 3-way ? ... they will definitely go harder in 3-way mode.
Peter
Peter I'm running the system 3-way. JBL does not run opposite polarity in this box I have checked that already. I did have a older pair of cabs that where like that. I will try to running the sub up to 120 and check the delay again. So you don't feel that smart would make a big difference?
Someone mentioned that they have sliding filters - they don't. Meyer had sliding filters, not Apogee.
If you were entertaining the idea....
Used Apogee Model A 3 Loudspeaker Management Processors Nice | eBay
