Lisa Young
Ventnor, NJ
Asheville, NC 6.12.19—The all new A-Series introduces a unique loudspeaker concept that sees advanced waveguide design combined with d&b enabling technologies – it questions everything. With flexible splay angles, this evolutionary system addresses a wide range of medium size applications where the highest levels of coverage flexibility is paramount. The A Series will be make its debut at InfoComm Booth #6761, demo room #W232AB.
Realizing all the adaptability of a point source cluster with the extensive control options of a d&b line array, the system comprises the AL60 and AL90 loudspeakers, with ALi60 and ALi90 offering cabinets designed specifically for permanent installation.
Both loudspeakers share a passive 2-Way design featuring one 1.4” exit HF compression driver with a 3” diaphragm mounted to a waveshaping device, and two 10” neodymium LF drivers. The combination of sophisticated waveguide design and the symmetrical dipolar arrangement of the LF drivers allows a smooth...
Continue reading...
