Audio / Log taper confusion
Re: Audio / Log taper confusion
One apparent difference between using a pot (to A/D) versus digital encoder is that the pot will provide absolute information.
Good point. The absolute nature of position from a pot can be a plus or a minus. On the plus side, there is no need for homing upon power-on -- persistent position memory, if you will. This is good for mission critical stuff, like position feedback on a missile vane servo, for example.
As you point out, a gray-code digital encoder also gives absolute position, and I suppose these days there's a built in gray-to-serial encoder so that it's down to one or two wires no matter how many bits.
I'm straying pretty for off topic here. Maybe I'm a little starved for this kind of talk :)
--Frank
Interesting, Frank. It seems to me that another couple reasons that pots may be chosen as encoders for digital systems is that control can be accomplished with one gpio pin (well, gpio's with a/d convertors anyway) and with simplified decoding in the microcontroller. btw, wikipedia says that most consumer audio controls are mechanical rotary encoders. I must say, the radio in my now defunct 2003 Dodge Grand Caravan was getting difficult to work. Sometime a clockwise turn would result in a reduction of volume rather than an increase. I had the opposite problem with a rack mount digital audio recorder the other day. I couldn't get the record level to adjust any lower than about -5db (and I needed something closer to -12db). In both cases I have to wonder if a pot would have been better.
Drew, this anecdote is a perfect illustration of what's happening to our digital encoders, and the reason we're considering going analog. So really it's a physical robustness issue, and advantages of absolute levels vs relative levels for certain kinds of non-tech-savvy users.
This sounds like a dirty contact in a quadrature encoder. If this were a potentiometer, it would also be scratchy and jumpy (although may not have gone through quite as many mechanical cycles).
That graph looks way off to me. With a linear rotary, attenuation at 12:00 is 6dB. With an audio rotary, attenuation at 12:00 is commonly 20dB.
There is no 12 o'clock on the graph in this thread.
for linear taper .5 rotation = .5 voltage division which is -6dB
for log/audio taper .5 rotation= .1 voltage division which is -20dB.
