hello all!! i'm back with some more questions, this time with the Mid-Highs.
First off.. i would like to thank all that helped/contributed in the subwoofer thread.
Just an update on the subwoofer - i decided to go with 6.8 cuft with 37/38 Fb (Don't remember exactly), Drivers came in about 2 weeks ago, wood is all cut and now I'm just waiting for other accessories. should be all done in about 10-15 days.
now, i need help with Mid-Highs -
i am thinking of going with B&C's suggested designs F122A (12PLB76, DE82TN & ME90) or F122AN (12NW76, DE820TN & ME90) depending on which drivers are available.
- the main reason I'm going with this is because ME90 is a rotatable horn and i can use it either 80X60 (1 top under 2,1 or 0 sub per side) or 60X80 (2 tops under 4 subs per side). Right now i only have 4 subs under construction and it looks like i may need 4 more.
Problems -
-although B&C has provided the layout for the crossover, i don't understand it. is there a place or someone who sells them specifically for the above suggested designs?
-i would like to go with an inbuilt crossover rather than active - cos i think going active will make things more complicated for me, am i correct?
-do you'll think that i have chosen the right plan or i should look somewhere else? (also looked at the options at beyma. But, B&C or 18Sound is easier to source.
thankyou,
Problems -
thankyou,
