Re: Behringer P16 versus Aviom
I've always thought that so long as the same wires were connected to the same pins on both sides it didn't matter too much which wires were actually used. I believe I may need to test my CAT5 cables before use from now on.
There are actually two wiring specs that will result in a straight through connection, 568A and 568B. In most cases, either scheme will work just fine. A crossover cable is wired to 568A on one side and 568B on the other.
more info
