Re: Behringer X32 has a air leak in the mains!
Thanks guys,
Checked the talkback, not that.
Maybe I'm making a mistake, and there is no validity in the Main Out voltage readings.
On either 7 or 8 main outs (Compact), when the desk is first powered up, XLR pins 2 & 3 read 0.13mV (-78dbV). When I raise Main fader to 0, voltage goes to just below 3mV (-50dbV)
Once the Main fader has been raised to 0, the voltage stays at 3mV no matter where the fader is.....even all the way down.
Either turning the desk off, or changing the sampling frequency in setup, returns voltage to 0.13mV (when the Main fader is all the way down)
More baffling:
1. the speaker hiss stays the same, whether first powered up at 0.13mV or at 3mV, as described above with main fader down.
2. the hiss increases plenty when raising the Main fader to 0, even while the voltage stays at 3mV no matter where the fader is....
maybe i'm clueless on how to read, or what to make of, balanced voltages.
Things i do know though:
XLR's unplugged at mixer = no hiss. Speakers plugged into my old analog mixer = no hiss.
Thanks for direction, mark
