This is the array that was used for the Godsmack tour. Bruce Reiter and Jeff Goode along with several other mixers can give you their thoughts on it's effectiveness. I personally loved it and would prefer this over any array shape I have ever used for sub . The coverage is amazing.
View attachment 714This is similar to the Carrie Underwood array. This is half as long but twice as high. And obviously in the air.
This is the array that was used for the Godsmack tour. Bruce Reiter and Jeff Goode, along with several other mixers, can give you their thoughts on it's effectiveness. I personally loved it and would prefer this over any array shape I have ever used for sub . The coverage is amazing. And you can blur your vision at 100 feet. I will not go into technical details here, but I can tell you how this started.
I had never used an array of this type. The goal was to get a more efficient array for the subs and to try to clean up the garbage onstage that is inherent in stereo stacked sub arrays. I was not sure if the flown array was going to have the kind of musical impact that I want for a heavy rock show. So I added the 4 subs per side on the ground and used them as a small centerfill pa. They were useful for putting the frontfill boxes on, because they never got turned on. The flown array had so much impact it was insane. But the band was asking if the low end was on. Perfect. The first time I had no points out in the house to fly the subs, they had to be stacked on the floor. The impact on the stage was huge. And not in a good way. Monitor mixes turned muddy, and the complaints started. This was from a heavy rock band that had gotten used to really good ear mixes because the pa wasn't interfering with the engineers job.
I think that non traditional sub arrays are going to be the way forward. The giant stack of low end boxes in front of the most expensive seats will be a thing of the past. And they should be if you really want to give everyone a good audio experience. It takes a little more work and you have to have some juice with the production to get them to agree to seeing this large thing there. And of course, listening to the local toolbags opinions about how subs were done in 1972.
