Re: Casual JTR Noesis and Danley SM80 meet up-also QU24
I would like to see Danley do some work in the area of manufacturer-supplied presets. We did a shootout with several Danley boxes vs other manufacturers, and ended up choosing a different manufacturer because with three rounds of tuning from a very qualified operator, we were unable to make the Danley product sound as good (SH60 in this case) as another manufacturer's box. This particular manufacturer has spent a lot of time on processing.
"Presets" are an interesting topic.
It depends on what you are looking for in a "preset"
Are you looking for a linear response? Something that will accurately transfer what is coming into the box into what is coming out of the box?
In many cases people will say YES-that is exactly what they are looking for. But how are they judging this? With live material in which case they also have a mixing console to adjust the individual channels tonality as needed? in most cases not.
They are using prerecorded tracks. So often what we 'prefer" to hear in prerecorded tracks is NOT a linear response-but one that is tilted on the top and bottom.
And it also depends on the level you are listening at. What sounds good at low levels does not transfer to high levels. But if you were mixing a band-you would simply pull out the offending freq on the channels that needed it. But you can't do that with tracks-so the eq (around the 3-4Kish "harsh" range) for the whole system will need to be changed as the level goes up.
Also the tracks being listened to will have very different "sounds"-so often adjustments need to be made in that regards.
I have had a number of people tell me that they don't like the sound of the Danley speakers because they want something that "feels like an icepick in the forehead" and makes your eyeballs wince and hurt the top of your nose.
So as you can see different situations and different people like different things. It really depends on what you are trying to "accomplish" with the sound system.
In many cases what people say they want-and what they choose are very different things.
There is no pleasing everybody.
And just to add-many people just listen on axis and make their judgements based on that. But in reality most people are NOT on axis and all over the place. Having even coverage across the intended coverage area is important.
To me it is more important that everybody hear close to the same thing-rather than a couple of people hear really good and most of the people do not.
But again-it depends on what is important to you and the particular situation.
