Hi,
Looking for a VERY inexpensive amplifier with onboard DSP to power a couple of small low powered horns at an install. I just need 100W per side at 8 ohms.
Something along the lines of a Crown Xti1000, Peavey IPR, or other similar entry level power amp with some reasonable DSP will suffice.
Please let me know if you've got something used sitting around that you can part with.
Cheers
Jeff
Cheers
Jeff
