Has anyone used their Flexsys speaks and or their DVX monitors.
I guess I am trying to compare is are these speakers close to peavey QW sound quality?
When I demo'd the DVX DM12 for wedges; I was going into purchase a 4 set deal of SRX712m at a smoking price to replace my MRX512m.
When I was demoing the DVX DM12, I had the wedge tickling the limiters and then I walked into the beam/path of the wedge… that thing ripped my head off.
I’ve heard the Flexsys FM12 a couple times; it sounds like a less powered version of the NX12SMA.
If you are looking to replace the Yamaha Clubs or JBL MRX512m level speakers, then the Flexsys will be fine. And if you looking to replace your QW wedge or SRX712m, then the DVX DM is a great candidate.
Own and use both , Flexsys is value line and does sound very good DVX is the pro line and will rip your head off and does not break up at high volumes. I have sold a lot of the DVX around the country and everyone is amazed by these boxes..we have a video or two on YouTube showing the inner workings of both series. Look under trinityprosound on YouTube.
DB Tech's website does not say what the dispersion pattern is for the FM8, FM10, and FM12. With some scrounging several months ago, I found that the pattern for the FM10 was 90x40, but elsewhere heard that it's 60x40. Does anyone know what the patterns actually are?
This youtube vid definitely seems to suggest the 12 is 60 rather than 90 for its wide plane, you can actually see the "60" on the face of the horn from about 6:30 onwards.
Same here for the 10.
Couldn't find anything on the 8, sorry.
David.
I've had a look at the manual that came with the FM10's and it's the same manual for all three. It says them FM8 is 60X60 and the FM10 and FM12 are 60X90.
Chris
Chris
OK, I stand corrected - I'd assumed from the shape of the horn in the vids that 60 was the wider plane, I didn't think there was enough of an angle on the other plane to be as wide as 90 but I'll have to defer to the maker on that one!
