Re: Digital mixer - pros and cons?
I didn’t think of the ‘doo-wop’ method and it definitely would have some advantages but since they each have their own wireless and they each seem to need different EQ on their mics for their voices I don’t see it working for them. But thank you for the suggestion.
There actually should be 10 monitor mixes to eliminate a couple of shared mixes that would be better if they were separate. At the moment they are all on wedges and there is no way I am going to recommend personal mixers unless they were on IEMs. I also am a big believer that the personal mixer doesn’t work for many people. It only changes who they can blame or what they blame them for. I think that most people just keep adding more to their mix instead of mixing it properly.
I also wanted to add that when I mentioned I didn’t work for the church it was just to clarify my role. I was in the past employed full time for 10 years as the technical director for a church.
this also made me think of a far simpler solution that i've seen done by a lot of the 'doo-wop' groups i've worked with. of course, they'll probably never go for it, but there you go...
they would just have a designated 'lead mic' that was hotter than the rest in the house and monitors. when someone sang lead, they used that mic. when they didn't, they used one of the backing mics. i remember the first group i came across that did that [national name although it escapes me which one... one of the old motown groups...]. i was all freaking out because they said they traded off leads and i didn't know who was gonna sing what. but they told me to set it up just like i said, and sure enough it worked like a charm. i pretty much just sat there and listened to the show... nicest part was that if i did need to tweak the lead vocal, it was always the same channel. super handy...
like i said, they'll probably never go for this. but it is the best, and easiest, solution....
p.s. i just picked up on this... EIGHT monitor mixes from FOH? seriously? ummm... it's time to talk about a personal monitor system of some kind. in my experience, 4 mixes from FOH was my absolute cutoff, and even that was really difficult to keep track of. 8 is just nutty...
