How do I keep moisture out of LED DMX lines? Seems like the cable ends can be a tiny bit wet and my lights go beserk.
They are Chauvet Slim par 64's
Get an IP rated fixture, and use the IP rated connectors. I have a feeling its not just the water that's causing the issue, do you have a terminator at the end of the DMX chain?
No terminator, but when its dry, they work fine. There may be a few mic cables in the mix. Gettin all DMX this week and a terminator as well. I want a splitter and a few are amplifiers as well. Will this help?
All DMX splitters also function as amplifiers.
Amplifiers in DMX world are snake oil... Honestly the only time you should need an amplifier for a dmx run is if you are going over 300' anything less and there is no issue. The splitters will help you with your cable paths but whats going to make that difference is find a way to keep the lines from getting wet. A terminator can solve issues but it may not solve this issue.
You can go 1000+ feet with no issue.
Sent from my SCH-I545
You are correct I had meters and feet mixed up, 300 meters is what I should have said.
Sent from my XT1060
Should I run a 100 ft DMX cable instead of using the snake?
