Cleaning out the shop sale. I need to get all of this gone quickly so feel free to make offers if you think my price is off on anything. Definitely open to discounts on multiple items. Please no offers under $50 on the little stuff. Shipping cost are additional from Raleigh, NC 27601
Please no PMs, email me at thomas dot dameron at vintagenc dot com
Pictures at: https://www.dropbox.com/sh/b1lkcuyt3lz5ezb/AAD6psobZDSMm4TXMDggylJRa?dl=0
Audio
(4) PAS FT2.2 speakers. 12"+2" Coax. Bi-amp only. Flyable (will include aircraft hanging clamps at no charge), pole mountable. 2" is a B&C DE-750. Well cared for all original parts. Rat fur finish shows it's age but is in decent shape. All grills are in good condition. I have presets for Ashly processors and Qsc Pld. $1,200 for all 4 OBO.
(2) Custom 8’ speaker stand. Rigid one piece steel. 1 3/8” top. Bottom bolts to standard 1’x1’ truss base plates (not included yet). Painted grey. $250 for both.
(1) Qsc RMX-850 amp. Good condition. $200
(1) Crown CE-2000 amp. Banana and speakon output version. One channel had a scratchy pot intermittently but tests ok now. Priced and sold as is anyway. $150.
(1) Motu 8pre. Firewire version. Mint, brand new, never racked. $200
(1) Motu 896-Mk3. Firewire version. Very clean, minor rack rash. This has build in DSP for EQ and compressor on every in and out as well as reverb. $200. Buy both Motu boxes and I’ll throw in FW patch cables and adapters for FW400,600,800 and Thunderbolt.
(1) DBX Driverack PX. 2 in 4 out DSP specifically for powered speakers. Great condition. $175
(1) Aviom An-16i analog to aviom converter. No power supply. Good condition. $125
(1) Aviom 16/0-y1 16ch V1 MY card. Perfect condition. $575
(1) Behringer DSP110 Shark. This is that little 1 in/1 out DSP. Good shape. $25
(1) Shure SM-11 Omni wired lav, terminated to xlr. New in box never used. The cap is super huge and not discrete at all. $35
(1) Radial Bassbone DI/Pedal. Great condition. $175
(2) K&M fixed angle speaker tilters. Perfect condition. $50 for both.
(3) 10' 8ch Hosa TRS snake
5' 8ch Hosa TRS-RCA snake
10' 8ch Gepco Xlr-M to bare ends snake
10' 2ch VTG TS to Xlr-F snake. Not sure why it's only TS but it could be converted to balanced TRS.
10' 4ch VTG snake. 2pr are RCA to Xlr-M, 2pr are TRS to Xlr-F
200' 28pr 20x8 VTG snake. Amphenol 85pin multi pin at console side. Stage box is not rack mountable. Excellent condition. The fan out mates to the snake perfectly, but the dust cap for the fan out is loose. $300.
~150' 19pr Alpha wire snake (grey). Mostly unterminated Rapco color coded heat shrink kit installed on both ends.
Lighting
(2x) Applied TM6-600 6 channel DMX 5 pin dimmers. Stage pin outputs, Edison inputs. Excellent condition. $650/ea.
DMX controllable fiber optic curtain engine. CYM color mixing. Needs new lamp. As is. $50 (no picture yet)
(10x) ETC 50deg S4 barrels. Some are original version, some are current. All good condition. Includes gel frame. $75/ea
(2x) 36deg S4 barrels. Current version. Good condition. Includes gel frame. $75/ea
(2x) 19deg S4 barrels. Current version. Good condition. Includes gel frame. $85/ea
(3x) Silver body par 56. Includes NFL 300w lamp. Terminated to Edison. Includes gel frame, safety and iron c-clamp. $45/ea
(3x) Silver body par 56. Includes MFL 300w lamp. Terminated to Edison. Includes gel frame, safety and iron c-clamp. $45/ea
(2x) Silver body par 56. No lamp. Terminated to Edison. Includes gel frame, safety and iron c-clamp. $15/ea
(4.5x) Altman 65q fresnel. 4x in good working order, 1x with intermittent lamp socket. Terminated to Edison. Includes 4x barn doors, safety, and iron c-clamp. Includes 5x 500W BTL lamp and probably a couple of spares. Buy a couple of them and I’ll throw in the bad socket one for parts. $75
(1x) Strand 6" fresnel. Good shape, terminated to Edison. Includes barn doors, safety, and iron c-clamp. 500W BTL lamp. $65
(2x) TLS side arm clamps. Nice black powder coated aluminum. 17.5" boom arm. $50 for both.
(12x) 7.5" half hats for Altman 360q among others. Perfect condition, most are NIB. $75 for all.
DMX cable. Lots. Mostly VTG 2pr 5pin. 250', 100', 75', 50'. Let me know what you want and a price/ft.
Video
Kramer VP719S 7:1 seamless switcher. Includes remote control. Good condition. $150.
Kramer VM-4HDCP 1x4 DVI DA. $75
Kramer VM-4Hxl 1x4 HDMI DA. $75
Kramer PT102S 1:2 S-video DA. No PSU. $10
Kramer 401Dxl component to YC decoder. $10
Kramer PT201 VGA 2 to 1 punch switcher. $10
(2x) Kramer VP111 VGA 1 to 2 DA/Line driver. One out loops, one is buffered. $20/ea
(2x, maybe more) Kramer Pico converter PT571/PT572 HDMI over cat5 transmitter and receiver pairs. $35/ea pair.
Gefen DVI over cat5 transmitter/receiver. Cat5MS extreme-R. Requires two cat5 runs, one for video, one for sync. Old technology, as is. $10.
Gefen USB-VGA converter. Legacy product, but I can email the driver. 1280x1024 max resolution but will do 16:9 AR. $25.
Vidco VDA300 1:3 VGA DA. 3 buffered outputs plus loop through. $25.
Manfroto tripod. 3001 B-pro sticks with 3030 head $50
Manfroto 3160 head. $25
Mustang MV-Projsp-flat white small projector mount. NIB $15
Mustang MV-Projsp-flat white small projector mount. Used $5
Unknown small projector mount. Free if you buy something else.
Unknown small TV wall mount. Free if you buy something else.
VGA cable. Lots. 100', 50', patch. Let me know what you want.
Other
(2x) Atlas SACS-5 12 outlet vertical mount power strip. Works as is as a power strip. I have no way to test if the power sequencer function works. $25/ea
~150' 10ga/5c Carol SO power cable Hubble L21-30-F connector + bare ends
(2x) Middle Atlantic 1ru extendable rack shelves. Good condition. $50/ea
3ru fixed rack shelf. Kinda beat up. $5
(2x) 2ru fixed rack shelf. Kinda beat up. $5/ea
1ru fixed rack shelf. $5
(2x) 1ru flanged blank panels. Some are nicer than others. $5/ea
(4x) 1ru flat blank panels. Some are nicer than others. $3/ea
(2x) 2ru flat blank panels. Clean-ish. $5/ea
(4x) 4ru flanged blank panels. Some are nicer than others. $5/ea
(2x) 6ru flanged blank panels. Some rack rash. $5/ea
4ru hinged blank panel. Some rack rash. $15
6ru hinged blank panel. Some rack rash. $15
(2x) Middle Atlantic UNI-1 punch out 1ru panels w/ various Neutrik connectors. $10/ea
Middle Atlantic UNI-1+ punch out 1ru panel w/ 2x xlr-m, 1x xlr-m, and 1 empty punch out. Both Xlr-m terminate to 1/8" $15
Audio
Lighting
Video
Other
