Good guitarists getting bad advice...
Jay Barracato
Graduate Student
5
38
Solomons MD
I have wanted to do a post discussing what I feel is a misapplication of a technicians "rule of thumb" that totally disregards the underlying principals. And then I had a band in Saturday whom I am close to, and I found out they have been getting the same B.S. in other clubs they have been into.
So hear it goes...
During setup the lead guitarist tells me that he is going to try pointing his amp at the wall because it will make the FOH sound better. The same story that gets repeated as some sort of celestial truth tha tis beyond questioning. Well I am going to question.
I told the guitarist that I would be up during the first break to help him turn it back around when it didn't work.
This is a band that has 4 monitor mixes, not in ears.
This is not a church where the entire FOH mix is limited to 90 db.
This is not an A list rock band playing a 65 x 45 stage.
So here are my thoughts:
Clarity trumps volume. A single source is always clearer than multiple sources.
By the end of the first set, because no one could hear the lead guitar, I had added it , by their request, to all five mixes. Add in the amp pointed to the wall and the bleed from FOH, each person was hearing at least 7 arrival times, that changed in every position on stage.
So by following the same B.S. that gets repeated over and over, they created a muddy mess for themselves on stage. But is that a worthwhile compromise to live with if it makes FOH cleaner?
Maybe, except I would rather have 1 amp bleeding into FOH than 5 monitor channels. Especially considering the guitarist plays a Mesa cab that is shaped like a wedge tilted back 60 degrees and he places it on top of a 3 foot high rolling rack on stage. So when you add in the 3 foot stage height, I guess the bleed would be of concern for any 24 foot tall spectators in the front row.
Localization trumps volume.
At the same time, the second guitarist/lead singer, who has his amp on a 3 foot tall rolling rack also, placed on the other side of the stage, can't distinguish between his guitar and the lead guitar in the wedge because he has lost the spatial orientation of the sources. Instead of having each clear source clearly to one side or the other, now both sources are just coming from a single point at the wedge. A simple widget to give 10 degrees of tilt back and his amp would be a non issue in FOH as well.
I am really getting tired of telling guitarists to turn up their amps. If you want to ask for guitar in your wedge at your playing position, your amp is either not pointed the right direction OR IT IS NOT LOUD ENOUGH.
And for all you techs with "turn it down-itis", if the band is not in one of the three categories above, stop spewing nonsense. It is a fricking rock show and guitars are part of the genre.
Re: Good guitarists getting bad advice...
I concur with the direction thing. On the side facing the band would make sense. I never have guitarists that are not loud enough, many aiming their amps in the wrong direction, usually at the back of their knees.
I have had some luck on the side of the stage pointed across the stage where all of the band can hear it. I get the best results however by bringing enough rig for the gig and delaying the mains to the backline though.
Funny you should say that.
I've had a feeling for years that guitar players that rely on monitors/iem don't perform at their best. The same goes for any one in a band except the keyboard players, they seem to cope with it.
For the guitarist, my experience.. Without exception....is that if I block their amp with a plexi shield it helps everyone. It cuts the out front high frequencies, and it create a really good 'zone' on the stage where the guitar sounds great to the player. I have had many guitarists buy their own or insist on using mine after their first experience.
How do you position it?
I attended a rehearsal for tonight's NYE show. Everything and everyone on stage is too fucking loud. Most of it seems to stem from "artistic" choices about "tone", but also from the placement of amps relative to the players. Upstage 10' and offstage left or right by 15' means the player is mostly out of the coverage. "I need to turn up, I can't hear myself" when I'm measuring 105dBA at FOH (85' from the stage) seems stupid and contrary to the artistic desire to provide the audience with a reasonably uniform experience.
The lead player was accommodating, with a case lid in front of his amp... but it creates the multi-path problem that Jay brings up and contributes to the "I can't hear myself" (when they really mean "I can't make out what I'd doing"). The drummer bashes away because he's surrounded by the backwash of 3 guitars, a bass rig that is all mud, and keyboard player trying to hear himself over the din. Bah fucking humbug.
I like the guitar as an instrument, but too many of the players make me want to use them as firewood.
I really, really wish cymbals would burn easily because they would be first in the blaze.
I usually let them position it if they want. With a 3 or 4 section shield you can get creative...actually feeding out the sides if helpful.
It can be moved closer or farther away if needed to sculpt the zone where the guitarist wants to be.
I was thinking of a simple piece of lexan bent at 150 degrees that could be slid under an amp on the floor, on a case, or on a stand. Just enough of a bend to give the feel of an amp sitting on the floor with a little tilt back.
Sent from my DROID RAZR HD
I was going to have someone make me a wooden stand with different angled slots that could slide a piece into and adjust the angles. I have found that the 3-4 section stand up version gives the most flexibility for horizontal adjustment. Again, if the amp is on the floor on stage the front reflections can be angled to other band members, maintain the spacial cues you spoke about. The sound from the front of the amp can be directed towards other players, the sound emanates from the actual source...the amp... And because of the angles it keeps it out of vocal mics. By moving it closer or farther you can control how far in front of the amp will be a high frequency hot zone. It has been described as 'keeping the sound on stage' which was a good feeling for most players who don't have to keep turning up.
I worked this out during my 4 years at my nightclub, which had a 4'8" high stage and without help the guitars on stage were ripping people's heads off.
So hear it goes...
So when did this nonsense start?! I've been on the knob side of the board a couple of times when full grown men and half stacks were on a smallish trailer stage and the weenie with the pointy guitar wanted some in his wedge!!! WTF
One thing you can count on when we play - nobody ever has to ask for guitar in anyones monitor. Monitors up front are for vocals.
That can also mean that the guitar amps are to loud. And that creates a whole new set of problems.
I would rather have quieter guitar amps and run some guitar through the monitors for people to hear them. That makes for a much better overall sound with less bleed through into other mics.
The LAST thing I want on a stage is somebody who says "Don't worry-my amp is loud enough by itself".
Plus once the stage gets large enough EVERYONE wants guitar...and other things.. In their monitor.
I think the issue here is that there is quite a bit of advice that addresses symptoms of the larger problem without actually addressing the fact that many bands simply don't know how to play as an ensemble. For any bands reading this, try practicing without any monitors whatsoever except for a single vocal wedge (no FoH either). And no earplugs - if it's too loud in your rehersal space, it's too loud for many small venues. Do what you need to hear each other and get a stage sound that is at least close to what you want the band to sound like. And then perform the way you have rehearsed. You'll probably find that you end up with at least some of the amps pointed at each other, and you'll certainly find that performing in poorly equipped venues is less stressful since you aren't relying on the monitor mix for anything except vocals. Oh, and you'll sound better as well.
</rant>
+1 !!!
I use IEM's with 4 individual mixes. When I used wedges, I still blocked the guitar amps with a plexiglass shield (and turn them around).
Beaming the guitar past the knees of the guitar player gives very uneven coverage at FOH. It can be painful on one side of the stage, and nearly inaudible on the other.
If you don't have that many monitors, you can get an amp stand and point it at the guitarist head ...... but I don't care for that either. It has been my experience that it encourages the guitar player to go off into his own world hoping that the rest of the band will sync up with what he is doing instead of playing with the band.
High stage noise is a pretty bad thing for a good mix IMHO. Cymbals, snare and guitar seem to be the biggest offenders. I mixed a band last year that put the lead vocal mic into clip with every snare hit (of course every snare hit was a rim shot by a guy with gorilla arms).
</rant>
what he said
