Re: Help me understand the concept of speaker “throw” please.
Hello
Potato masher was also known as "peppermill"
Hello
The higher humidity actually HELPS the freq response at distance.Yes and add about 80% humidity to 35 mph winds. Thats why they call them The Cheap Seats
Ivan
The higher the humidity the lower the density.
The water molecule has a lower mass then nitrogen or oxygen.
Sent from my DROID RAZR HD
What? Water has a lower mass than Oxygen? Please explain.
Oxygen is diatomic.
Right, and a water molecule has two oxygen atoms(H2O), so how does a water molecule have less mass than oxygen?
I don't qualify as a "physics geek", but sound travels about four time farther in water than it does in air, so it is only logical that, as Ivan stated, "the higher humidity actually HELPSthe freq responsewith transmission at distance".
Water is two Hydrogen atoms and a single oxygen not the other way around.Right, and a water molecule has two oxygen atoms(H2O), so how does a water molecule have less mass than oxygen?
Water has one oxygen atom and two hydrogen atoms, so while the molecular weight of O2 is 16+16=32, the molecular weight of water is 16+1+1=18. Nitrogen is slightly lighter than oxygen 14+14=28 and CO2 is very heavy in this comparison at 12+16+16=44. Not that there is a lot of CO2 in the air normally, but it might get higher inside a full auditorium.
However, normal dry air have an average molecular weight of just under 29, so the water vapour is significantly lighter.
When discussing sound, O2 is rather less relevant than N2, it is actually the nitrogen that mainly governs how sound behave,
....and oxygen is only responsible for the misbehaviour :razz: .
A hard core audiophile would not only have oxygen-free copper in his cables, but be listening in an oxygen-free atmosphere~:-D~:grin:
To add, nitrogen gas makes up around 70 percent of the air most of us breathe
So based on that Ozone O3 should be 16+16+16=48 and heavier than a lot of gasses in the atmosphere?![]()
Thanks Jay for the lucid explanation. I share your low regard for so much of the climate change blather.
@ Glen "dew point" ...
Call me confused.
water is more dense, vibrations are almost lossless. Except that it propagates out in all directions in still waters. I would think the inverse square was a cube but I am no scientist, but I did stay at a Holiday Inn Express last night.
But where I get confused is that water vapor is another animal. I've done so many outdoor gigs in high humidity, ( Eastern PA ) fog horn capital of the pro audio world. And every time night time came and the due point fell the sound got better, clearer, cleaner, as in more highs. I don't know if it went further just that early evening it sounded like a rug was over the system, and after the humidity dropped the rug came off.
splain that one please Billy Nye
