Can I do this, I know its not balanced but the desk does not have balanced inserts anyways. Can I use one conductor of a mic wire and go to the tip, shield to sleave, take the other conductor and solder a 1 foot jumper, ( sheilded mic cable) to the next 1/4. Of coarse the sheild will be jumpered also.
On the hosa insert cables I use now the 2 insulated wires are individually shielded, doing what I want the two insulated conductors are together, sheilded by one.
Will this cause a issue of the send and return running side by side under 1 sheild, vs having the send and return individually sheilded.
This is the cable I use
20 Channel Stage Studio Microphone Snake Cable per Foot | eBay
