Good day all,
I have been doing several fly-date corporate gigs lately where RTS intercom systems are being supplied. I keep a Telex PH-88 (with 4pin XLRF connector) in my Pelican for these gigs but I end upi having to use the often supplied bulky Beyer DT-109 headsets instead of being able to use my PH88 as the RTS beltpacks (BP325) have a 4pin XLRF connector as well as a 5pin XLRF connector (labeled mono headset for the 4pin and stereo headset for the 5pin). As the PH88 headset is mono one would assume that I could just get a 4pin XLRM barrel and use the 4pin XLRF connector on the BP325 although it makes no sense to me why RTS would put a female connector on their beltpacks. My question is quite simple - is that all I need? i.e. a 4pin XLRM barrel to make my PH88 work with RTS 2-ch intercom beltpacks or do I need to make a custome 5-pin to 4-pin adapter cable and use the 5-pin XLRF connector on the beltpack which is what the Beyer DT-109 uses to connect the headset to the beltpack?
Thanks
Hal
Thanks
Hal
