Simply put I have a large system setup and the issue that I’m having is:
On a clean frequency, and simple connection into the combiner and out to an antenna
As I walk the pack, (no audio) I am getting a very loud noise floor, (hisses, pops, intermodal sounds in some spots, etc)
Things I have tried, swapping out all cables, switching between Omni, helical, and log periodic antennas, all have the same issues with no audio passing, however, when passing audio, even at a low level, most, if not all of the artifacts goes away. I am also able to walk about 300+ feet away from the antenna and still receive a strong signal.
I’ve never had this problem from either the PSM1000 or the shure combiner before. Has anyone else encountered this problem or have a solution? Any thoughts would be appreciated.
(PS. I am troubleshooting with 1 frequency as to eliminate any internal intermod...
