Is there another version, Tim? If there's a standalone one, I'd download it right now. I always thought it was web-based.I'm using the HTML version right now.
EDIT:
Well look at that! There is one! Get it here, at the bottom of the page.
I'm using the HTML version right now. You can grab any audience plane point with your mouse and move it around. Likewise, you can grab the array and move it higher, lower, up or down stage.
As I move the B point around the numbers at the bottom change but the room size stays at 66.25 x 100 ft, a completely random number as far as I can see. But I guess I can ignore that and read the numbers at the bottom.Yes I got that, but the numerical dimensions in the display don't change as I move the points around. So I have no idea if my room size is correct. Maybe the downloadable version works better but I'm having a problem downloading it.
Mick Berg.
