I own 20 or so k series boxes already. when I need more than a pair of k12 over kw subs and maybe some delay boxes then I rent a big srx rig. I dont see a need to own really big racks and stacks but Im looking for another pair of speakers so that I can cover gigs just a bit bigger than the k12 can handle such as smaller outdoor gigs and the bigger ballrooms that are still small enough that they dont need a big array system (Ill just rent that when needed).
Would the kw153 work for this or what other boxes should I consider?
Does the kw153 even make sense since I will be putting them over subs?
Is the kw or anything similar still not enough and its time to make a bigger step up and own the srx rig Ive been renting?
thanks
thanks
