Hi Everyone.
I want to hang 4 JBL VRX932LAP's on the VRX-AF array frame with front shackle and rear point shackle and I want to connect those shackles directly to the Global Truss Heavy Duty (full wrap cheeseborough) Clamp with Eye Bolt. The max weight rating of the clamp is 440 pounds. The non moving weight of the array is 220 pounds including the cabling. I would then do a round sling as a safety.
Is there any reason why shackles can't connect to other metal other than wire rope thimbles, or chain lift hooks? Everything I have seen on shackles is slings, wire rope and chain motor hooks. This would allow a rather solid mounting to the truss that will be lifted with heavy duty lifts.
Thoughts?
Thoughts?
