Back in 2021, in the midst of the pandemic, Martin Audio unveiled their first constant curvature loudspeaker array, TORUS, featuring two variants T1215 and T1230. The products went on to be a stellar success, outstripping the company’s initial projections by 400%. It is perhaps no surprise, therefore, that via an online special event and at ISE 2023 in Barcelona, Martin Audio unveiled a smaller addition to the series, TORUS 8 (or T820 as the individual model is known).
T820 is a passive, two-way loudspeaker engineered for small to medium-scale applications which do not call for the longer throw capabilities of a line array. With exceptional ease-of-use, scalability and deployment flexibility, it is primarily used as an array element in vertical constant curvature arrays as well as being used singly as a point-source loudspeaker. In venues with short throws, yet high ceilings —as is the case in some theatres—a horizontal centre cluster may also be a practical solution.
T820...
Continue reading...
